Every time a word export template is modified, the word doc it creates has errors
RobSal
I'm using one of the default templates for exporting a word document. When I modify the word template, and try to use it for exporting a tracker, the resulting word document won't open, but a new doc is created. It says the document contains unreadable data.
Catalina
Moderator
(To:RobSal)
Hi @RobSal
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
