I try to export a full test case tracker with folders, item with test step and subfolder to word format.
see attached file (in french, but with explainations, tracker configuration and word template).
Codebeamer used: V22.04
BG,
Amaury
Hi Amaury,
The result of our investigation in the SalesForce case is this:
Kind regards, Eva
support request opened: #17325776
Hi Amaury,
Kind regards, Eva
