How to Integrate Git releases in codebeamer
Rubiya
"Iam not able to connect with git releases in codebeamer any suggestions getting fatal scm error only while adding releases in Git URL to add in codebeamer repo."
cristina.b
(To:Rubiya)
Hi Rubiya,
You mentioned that you have added webhooks to connect the repository. I am assuming this means it is a Github repository, as it requires a webhook connection.
Repositories created in Codebeamer via webhook are read-only and are limited to the information carried over in the webhook. The 'Releases' part of the repository may not be included.
Hi Rubiya
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
Rubiya
(To:achirila)
Iam Successfully able to Integrate Git with Codebeamer by Adding Webhooks and able to See all the Commits Done in Git are getting in Codebeamer.
Now Trying Create Releases in GIT but when connecting to Release URL of GIT in Codebeamer Getting Error like "Fatal Error SCM NOT found " only for Releases in GIT.
Where as able get Tags added in Git are getting Connected in Codebeamer As u see below Iam Able to see Commits , Tags etc.. In the same I want to Fetch Releases from GIT and Release Tab to See all Releases.
Getting below error when adding URL for GIT Releases
cristina.b
(To:Rubiya)
Hi Rubiya,
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
