How to fetch workitems for specific baseline by using Swagger API
NL_13073258
6-Contributor
I am looking for to fetch all work items in a specific basline id. I am not found it swagger API page. I want to fetch work items for specific baseline by using baseline ID
Hi NL_13073258
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Are you trying to retrieve all work items associated with a specific baseline across multiple trackers, or just within one tracker?
  • Is the baseline you're referencing a system baseline, a custom one, or part of a versioned tracker?
  • What specific data are you expecting in the response—just item IDs, full item details, or something else?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Rubiya
(To:Catalina)
Hi Catalina ,
We need an API end point to fectch the Baseline Tracker Items , currently we dont find any API in Codebeamer documentaion to fetch the items of a Baseline Tracker , Please provide the API endpoint by which we can fetch all the Requirement items in Baseline tracker like different versions .
Single tracker with Multiple baseline versions .
Need to fectch Item ID , name , status , type .
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
