How to generate Table of Figures and Table of Table in Word export
eazzarito
Hello everyone,
I am experiencing a problem exporting word using the procedure followed in the guide with both codebeamer version 2.2.1 and version 3.0.0
https://codebeamer.com/cb/wiki/4129797
I report the steps performed:
1. I create an item with a description (Screen1 and screen2):
2. Export to office by selecting the template "TableOfFiguresTemplate3.docx" that I previously uploaded in the documents section (I attach screen3)
3. From the word I exported I do update Figures but get the following message : "No figure index entry was found." (screen 4 and screen5)
Has anyone experienced the same problem?
Thank you all
Hi @eazzarito
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. For example:
  • When you attempt to update the Table of Figures in Word, are you using the "Update Field" option from the context menu or the "References" tab? Could you describe the exact steps you follow?
  • Have you checked if there are any specific settings or configurations in Codebeamer that might affect the export process?
  • You mentioned experiencing this issue with both Codebeamer version 2.2.1 and 3.0.0. Did you notice any differences in behavior between these versions during the export process?
Best regards,
Catalina
PTC Community Moderator
PTC
