How to show only last runs of a test case in a traceability report?
PW_10873009
Hi community,
I have the following configuration (codeBeamer 2.2.1.0.4).
This gives the following result.
Now, I only would like to see the latest run of this test case.
How can this be done in the configuration?
Or is there any other possibility to manage this?
Thanks in advance.
Best regards.
Pascal
Filter test cases by their last run result in a Codebeamer report.
You can explore the following options:
  • Test Cases by Last Run Result Plugin
    This plugin allows you to visualize the latest run result for each test case in a table or chart format.
  • Custom Computed Field
    You can also try to create a computed field in the test case tracker to pull the latest result from associated test runs.
    • Example formula:
      • first(1, downstreamReferences(this).trackerTypes("testrun").{item | item.resolutions[0].name})
Hi @PW_10873009
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
EA_10840595
(To:Catalina)
Hi  - i am not from ptc - so not an "official" solution. We do it with 2 calculated fields on the testcase,
the first gets the ID of the latest testrun (basically just the one with the highest ID) and the 2nd field fetches the result of the item with that ID.
Formulas:
to get the ID of the latest run: "Last Formal Run ID" = max ( distinct (downstreamReferences.trackerTypes('TestRun').{item | ((item.resolutions[0].id <= 4 ) && ( item.formality.name == 'Formal' ) ) ? item.id : null } ) )
to get the result of  that testrun: lastFormalRunID > 0 ? Item(lastFormalRunID).resolutions[0].name : 'No Run'''
This way you can display the last formal run in a traceability table.
if you need not just the result of the formal run, you can remove the condition in the formula of Last Formal Run ID field. if there is no run, the formula returns 0, that is why we have the condition in the 2nd formula.
    • Example formula:
