Merge Fields in Word Template export do not work when edited
MM_10991077
Hello all,
export tracker to word using eg. default system template works fine and data are visible.
But it does not work if Merge Field is edited:
 1) { MERGEFIELD  author \* MERGEFORMAT }  -> author is rewritten manually
or
2) { MERGEFIELD  author \* MERGEFORMAT }  to { MERGEFIELD  baseline \* MERGEFORMAT }
or manually inserted : Insert tab > Text > Quick parts > Field > Merge field
If working Merged Field is copy/past then it works.
Is there any special formatting or syntax needed for working with Merged Fields in Word document?
thank you
Hi @MM_10991077 ,
We have some articles regarding to description and Word export:
https://www.ptc.com/en/support/article/CS431288
https://www.ptc.com/en/support/article/CS405694
https://www.ptc.com/en/support/article/CS430570
Sadly I cannot identify the issue without more specific data.
Report it on the eSupport page where you can share sensitive data, and we can check this problem more detailed.
9 REPLIES 9
Hello @MM_10991077 ,
I usually manually insert them with the Quick parts > Field function, but without the { MERGEFIELD ... MERGEFORMAT } commands:
Hello EvaBertalan,
I did the same but for some reason it is not working.
the { MERGEFIELD ... MERGEFORMAT } is shown when you press ALT + F9
Below you can find picture with original working merge field and manually inserted via above step.
They look the same but it is not working.
thank you
Hi @MM_10991077 ,
Sorry, I cannot reproduce this.
Are you sure, you change it back with ALT + F9 on the exported document to see the actual result?
Hi @MM_10991077 ,
What is the version of MS Word you use?
Is it a desktop application, or an online application?
What is your operating system? Windows? Mac? Linux?
Hello EvaBertalan,
yes, I change it back with ALT + F9.
We use Office365 running on Windows 11 machine.
What confuse me is that it stop works when edit working merge field.
Pure open and close field window is enough.
result:
Hi @MM_10991077 ,
Mergefields are processed during the Codebeamer export.
They won't be evaluated if you change them in the exported document.
Try to change them in the template document.
See: https://support.ptc.com/help/codebeamer/r2.2/en/index.html#page/codebeamer/user_guide/ug_merge_fields_export.html#
Hello @EvaBertalan ,
I downloaded systems templates from: $CB_HOME/tomcat/webapps/cb/exporttemplates/Trackers
Templates work fine.
Below is example for tracker:
I made a copy of "template-items-all.docx" and delete all fields except Description (line 1).
Then created same merged field (Description mine).
And copy original description from first line (Description copied).
Made export to office:
Result is below:
There is also second issue.
I am not able to populate data from header in blue square on the first picture.
thank you
Hi @MM_10991077 ,
I will report it on the eSupport.
thank you
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
