Missing "create new project" Button in Free Trail Version
KW_10909569
2-Explorer
Hello together,
i downloaded the 30 day's Free Trail version of Codebeamer and started via browser login. Now, i can't create a new project, because the button "create new project" is missing. Is this correct in the free trail version??
best regards,
Kai
Hello Kai,
very likely you miss the permission to be able to create new projects.
You need to assign yourself as "System Administrator".
Create Projects is a permission linked to that group.
Hope it helps.
Hello Kai,
Hope it helps.
You are right, the user group should have the Create Project permission.
It is not just a System Admin perm, all group can have it, but it is mandatory to project creation.
Hi @KW_10909569
We do not have a Codebeamer Support Community yet. You can contact the Codebeamer TechSupport team using the eSupport portal as well. Create a case and we are ready to help you: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Andra
This topic has been moved from the "Codebeamer Ideas" to the "Codebeamer" forum due to its non-idea nature and in order to receive the visibility needed.
Catalina
Community Moderator
Catalina
PTC Community Moderator
PTC
