Report a Bug in a Project Different from the Executing Test Run
RT_10850232
2-Explorer
I would like to "Report Bug" in a project different from that of the currently executing Test Run.
When I select Report Bug from a Test Run, the Project dropdown only contains the project in which the Test Run is located. I would like to report the bug in a different project.
I am using CodeBeamer 22.10 SP 4.
Hi @RT_10850232,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Hi @RT_10850232
To view additional projects when reporting bugs during a test run, you must first access the test run field configuration page. Once there, click on the 'Work/Config items' link on the 'Reported Bug(s)' field. In the pop-up window, you can add a new project. Be sure to select the 'of type' filter, and then select 'Bug' under the new project, just like you do for the current project. Click OK, then also click Save on the main field configuration page.
Please let me know if this helps or if you have any further questions.
Brian Kampling - Source Allies
Brian Kampling | Software / Systems Engineering Consultant - Source Allies
Hello @RT_10850232,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
