Traceability with external SCM not visible in codebeamer 3.0
MM_10919030
External SCM commit items attached to a task item is not visible under the traceability tab of a work item, even after checking the show external SCM checkbox.
I have linked CB with Github using external SCM repository option.
I was able to get these items before updating to version 3.0, is there anything i am missing?
The problem was fixed after upgrading codebeamer to 3.1, thank you
5 REPLIES 5
Hello @MM_10919030 ,
This should still work in 3.0. Are you setting up the repository following this guide: External SCM - Azure Repository?
Thank you
Hello @cristina.b ,
Yes, this guide was followed for external integration with GitHub.
I can see my commit messages visible in SCM tab of the work item. But when viewed from the traceability browser, I cannot see any associated SCM commit items.
Hi, was it 3.1.0.0 or 3.1.0.1?
3.1.0.1
