Unlock items when closing browser
Ran
7-Bedrock
7-Bedrock
The company I work for develops several types of software.
I provide help with using CodeBeamer.
Responsible for everything from simple instructions on how to use them to contacting PTC for answers to complex issues.
If a user closes the browser while editing an item, the item will be locked and cannot be edited for the duration of the user's session.
It is common to close the browser without properly ending editing. In this case, users think that the content being edited will not be reflected and will end (editing will end), but in reality, not only will editing end, but editing by other users will also be blocked.
This is a kind of careless mistake.
But it happens more often than you might think.
When a user closes the browser and leaves, other users have to wait a long time to edit that item. This wastes unnecessary time for the user.
Even more so since the session time cannot be reduced to less than 1 hour.
If you close the browser in Edit Mode, is there a way to unlock the item?
alfonso_c
(To:Ran)
Hi @Ran , there could be other ways to handle this issue, I am sharing just an idea to remediate it once it happens: a user with permission to execute REST API calls could unlock the item with the DELETE /v3/items/{itemId}/lock endpoint:
  • <yourserver>/api/v3/swagger/editor.spr#/Tracker item/unlockTrackerItem
AS_10932076
6-Contributor
(To:Ran)
I can attest to this issue. It happens a lot and because the company I work for is global, sometimes the person isn't even working anymore and they just close their pc without logging out or closing a browser. It's frustrating to say the least.
alfonso_c
(To:Ran)
alfonso_c
(To:alfonso_c)
Hi @Ran , according to https://www.ptc.com/en/support/article/CS427862, it seems there are currently no other ways to prevent this behavior.
As my suggestion to use the DELETE /v3/items/{itemId}/lock endpoint is the only potential workaround so far, I am marking my preceding answer as "Accepted Solution".  If you have more to share on your issue, please let the Community know so other community members can continue to help you.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
