How to upgrade Codebeamer from 2.1 to 2.1.0.1
You can perform a patch: https://support.ptc.com/help/codebeamer/r2.1/en/index.html#page/codebeamer/install_guide/10469032.html
Or a full upgrade (works the same as a major release upgrade): https://support.ptc.com/help/codebeamer/r2.1/en/index.html#page/codebeamer/install_guide/14336937.html
Thanks for your response ..👍
Can you please tell me where I can download the Service Packs for codeBeamer 2.x. I only find Service Packs for codeBeamer 22.10 and earlier versions.
Please log in to PTC eSupport and click on the Download Software link. On the next screen, select the appropriate choice, and you should be presented with all PTC Products linked to your account.
Navigate to Codebeamer in the list and you should be able to access all latest released versions of the software. Hope the following snippet helps.
Kartik
Yes, I know. But the newest Service Pack I can find is 22-10-SP5-Service-Packs. There are no Service Packs for codeBeamer 2.x.
You should file a PTC Support case if you are not able to find it on the new support.ptc.com site.
Kartik
