Every time a Test Tun is created, the Release field is automatically filled with the first Sprint of the project. Is there a way to turn off the automatic filling? I hope to improve the function of turning off the automatic selection
Translated by the moderation using Google Translate
每次创建Test Tun时,Release字段自动填充为该项目的第一个Sprint。有无办法关闭自动填充,希望提高一个选择关闭自动选择的这个功能
Hello 源段_10897294,
Without checking the specific configuration of the Test Runs tracker, it is difficult to offer advise. Have you tried creating a filter for the 'Release' field, filtering by description, for example?
Let us know if this helps. Otherwise, please consider submitting an eSupport ticket with your issue, enabling you to share the project configuration.
Thank you
