Hello
I heard that files uploaded into the [Documents] tab in a project is, by default, saved on the directory <Codebeamer>\repository\docs.
Where is, on the other hand, the directory where files attached to a tracker is stored?
Are these files stored into the DB?
My codebeamer version is 22.10SP5
as you can read here:
https://support.ptc.com/help/codebeamer/r2.2/en/index.html#page/codebeamer/install_guide/93720.html
/repository/docs This directory contains all Codebeamer documents and attachments. The required disk space depends on the total size of all documents, the number of their revisions, and the size of all attachments.
Hi @TO_10566025
Thank you for your question.
lso, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
