Word Export for Test Run tracker Exception in thread "main"
MM_10991077
Hello all,
trying to Word export for test run tracker but get below error:
com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxMergeFieldExporter$ExportAppError: Error inside export application: Exception in thread "main" java.lang.reflect.InvocationTargetException
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkIfAnyExceptionOrError(DocxJvmExportManager.java:197)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:172)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.checkForErrors(DocxJvmExportManager.java:166)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmExportProcess(DocxJvmExportManager.java:149)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.lambda$runJvmDocxExport$0(DocxJvmExportManager.java:85)
	at com.intland.codebeamer.flow.form.ParallelProcessGuard.execute(ParallelProcessGuard.java:42)
	at com.intland.codebeamer.controller.importexport.export.mergefieldword.DocxJvmExportManager.runJvmDocxExport(DocxJvmExportManager.java:80)
	at com.intland.codebeamer.controller.importexport.export.job.ExportJob.convertToDocx(ExportJob.java:177)
	at com.intland.codebeamer.controller.importexport.export.job.ExportJob.doExecute(ExportJob.java:117)
	at com.intland.codebeamer.utils.scheduler.StopWatchJob.execute(StopWatchJob.java:66)
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)
Found similar topic in knowledge base where  suggested solution is:
  • Check if there are any deleted working sets recently.
  • If it is possible, restore these working sets and then perform the export again.
See below link:
https://www.ptc.com/en/support/article/CS424822?source=search&as=1
I don't know how to identify deleted working sets.
I am not an owner of tracker and only support user in his issue.
Maybe there is also another fix.
Codebeamer version 2.0.0.5
thank you
Hi @MM_10991077
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
