12/1 Weekend Maintenance
Ruby III
Problem seemed to be solved for a while but quite now it again took minutes to log in
36 REPLIES 36
Re: s l o w
Again! Problem not solved!
I was just about to cancel the process when finally after some minutes the login was successful.
It looked to me as if support.ptc.com was the problem and not lithium, but I may be wrong about that.
Re: s l o w
In case anybody cares - just now it took me 3 minutes and 20 seconds for being back to the community page after entering my login data at support.ptc
Problem not solved 😞
Re: s l o w
I am also seeing the problem again. I tried both Mozilla Firefox and IE 11. This reply was done via email and just as I was finishing, the login was successful on both.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Re: s l o w
To echo others comments, it took over 2 minutes this morning from submitting my credentials to seeing the page I was headed to (private messages).
LinkedIn
Re: s l o w
I just logged in.  Took me 2 minutes and 15 seconds.
There was some sort of maintenance done over the weekend. Did that get done correctly?
https://community.ptc.com/t5/PTC-Community-Announcements/PTC-Community-Read-Only-State-December-1st-...
Re: s l o w
@Dale_Rosema
Yes, we were included in the "shutdown" while the eSupport team had some backend changes.  As far as I know, that maintenance activity went as expected.  I have an open ticket with Lithium regarding my announcement area on the community.  This is why I haven't removed the message yet.  Thank you for checking in!
Re: s l o w
Funny thing is I never saw the message (other than the posting through PTC Community Announcements) until I just went to flag a MathCAD question posted in the wrong area. I seldom if ever go to the PTC Community home page so I never saw the "flag" / announcement.
Re: s l o w
Subcribe to the announcements board https://community.ptc.com/t5/PTC-Community-Announcements/bd-p/community_announcements
Its the only way I know since I pretty much only interact via email.
Steve Williams
