12/1 Weekend Maintenance
Re: s l o w
Jaime,
after weekend maintenance login to support.ptc.com takes 2 minutes 15 seconds. Please can you forward this "message" to appropriate PTC department ?
Martin Hanák
Highlighted
Re: s l o w
@Jaime_Lee, login today - 2 minutes and 8 seconds.
Re: s l o w
Same here, 2:12.  That is faster than it was a week ago, but still far too slow.
LinkedIn
Re: s l o w
@TomU @dgschaefer
Are you referring to login at community.ptc.com or support.ptc.com ?
Re: s l o w
I was coming in from the community, but don't they both use the same login?
LinkedIn
Re: s l o w
Logging into the community redirects to support.ptc.com and then back to community.ptc.com.  The hang is on the support.ptc.com page.
Re: s l o w
Like Doug said, they're one in the same.  Normally I log into the community first so I'm automatically logged into support as well.  Doing some more testing, the delay is the same.  It doesn't matter if I start from the community or I start at support, the delay is identical.  I've also confirmed that the delay is not browser specific.  I can reproduce it with Chrome, Firefox, and Edge.
Re: 12/1 Weekend Maintenance
Actually I post on the S L O W post because I thought maybe something was hung up in the maintenance  done over the weekend and was causing the issue to re-occur after the weekend.
Re: s l o w
So, I logged out of the community and then clicked login to check the address of the login page.  I was logged back in immediately, automatically.
So I clicked log out again and went to the support page (support.ptc.com) and when it loaded I was already logged in.  I logged out again and was presented with a different log in page.  That login worked fine, but considering how logging out didn't seem to actually log me out, I can't say for certain that it's working correctly.
Returning to the community it showed me as logged out.  Clicking log in resulted in being immediately and automatically logged in.
Not sure if any of that helps the slow login issue, but I thought I'd report my findings.
(Separate from the slow login issue, personally when I click log out I should be logged out and have to re-enter my credentials to get back in.)
LinkedIn
