12/1 Weekend Maintenance
Re: s l o w
Attempting to log into the community redirects to this page:  https://support.ptc.com/appserver/common/login/ssl/login.jsp?
To access support I use this favorite:  https://support.ptc.com/appserver/cs/portal/  It also redirects to the same login page as the community:  https://support.ptc.com/appserver/common/login/ssl/login.jsp?
If I log out of both the community and support and then attempt to log back into either one, it takes 2 minutes and 9 seconds before a response is received.  Once I'm logged into one I can access the other without having to login again.  (There is really only one login for both.)
Re: s l o w
Seems like maybe it's related to a redirect:
Re: s l o w
Thank you all for your feedback.  A ticket is open with the internal PTC IT team to research this!
Stay tuned to this thread for updates.
Re: s l o w
did you recive some feedback from IT team ? It is really annoying to wait 2 minutes to login ...
Martin Hanák
Re: s l o w
If I open a link from the email notices and then try to login, it times out.
If I open ptc.com and then open esupport, I can login fine. Once I am in, I can open messages from my email.
Re: s l o w
Wish it would only take 2 minutes as it used to be a few days ago!
At the time I am not able at all to login to from the community page - it times out.
But as a workaround I can login to support-ptc without problems. When I then go to the community site I am logged in. Annoying!
Re: s l o w
I am sending HAR file generated from Chrome.
2018-12-10: I removed an attachment, because it contains secure information (eg. username, password, company name) written in plain text.
Martin Hanák
Re: s l o w
@Jaime_Lee
Any news about this from your IT team? Its now about two weeks and the problem persists. At least since december first its a PTC only problem and seems not to be related with Lithium.
The same login delay occurs if we just log in at support.ptc.com.
Its incredible that a problem like this could not be fixed within two weeks!
Re: s l o w
@Jaime_Lee
Hi Werner,
please can you test following procedure ?
1.] launch browser (IE11, FF, Chrome)
2.] enter following URL into address bar
https://www.ptc.com/en/support/login?returnUrl=%2fen%2fsupport
3.] enter username + password
Note: The above procedure enables me to login immediatelly.
Martin Hanák
Re: s l o w
I'm seeing the same behavior.
Fast:  https://www.ptc.com/en/support/login
Slow:  https://support.ptc.com/appserver/common/login/ssl/login.jsp
Unfortunately both "support.ptc.com" and logging into the community redirect to the slow page.
