This is a test to see if the community is experiencing double posts this morning. I read it on someone else's post and on the humor post in PTCooler.
https://community.ptc.com/t5/PTCooler-OffTopic/2020-05-22-Friday-Humor-Over-designed/m-p/667431#M532
Hi, there, Community. Following up, double posting was resolved last Saturday. Thank you for drawing our attention to this issue.
Here is what I am seeing:
I am beginning to think this might be some some sort of setting. Is anyone else seeing this, because I am evening seeing it in old posts.
I made a post early this morning, and it turned into a double post. It's under Assembly Design.
When I kudo'd one of them, it kudo's both
Do I get two kudos then.... 😉
I just got new glasses this week so I'm 100% positive that you guys are seeing everything thru my new glasses...everything is doubled up. Its the only possible explanation!
Hi Community thank you @Dale_Rosema for bringing this to our attention. I think there was some configuration changes yesterday. I am looking into this as I type this message!
Wow - super multitasking. 🙂
Thanks for checking into it.
