appearance.dmt
DonSenchuk
7-Bedrock
appearance.dmt
Appearance.dmt file with a ton of HTML colors included.
4 REPLIES 4
DarylWolf
(To:DonSenchuk)
where do I put this in the creo 3 files so that it opens automatically.  I had it working in creo 2 but its not working in 3.   thanks.
It should work if you unzip it into your "start in" directory.
Alternately, you can set the config option "pro_colormap_path" to point to a directory containing the "appearance.dmt" file.
-Doug
I'm not sure about Creo 3. Does it not have a 'graphic-library' folder the same way Creo 2 does?
Anyway, the config option Doug mentions should work.
DarylWolf
(To:DonSenchuk)
that's where it is.  it works like creo2
the pro_colormap_path wasn't working.
thanks all.
