We currently use Projects within Model Manager extensively, at the moment when we get a new task, we create a new project. Is there a way in which projects can be archived once the task is complete. I know projects can be added within projects to create sub projects. But when a new search is defined using project as the main criteria it shows all the projects under the parent project. It would be nice to hide the archived projects so they do not appear in the project drop down when defining a search.
