We need a possibility to stop the current command, when Modeling and Annotation does not respond. We have no possiblitiy to insert a command in the commandline of Modeling or Annotation.
SD-kill.exe or Ctrl+Break or Esc does not stop the command.
The only solution is to close the Modeling in the Task Manager, unsaved work is lost.
