Create chamfer in 2D Editor
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Data storage company, mechanical design engineer, FPC (flexible printed circuit) design.
2. What product and version are you currently running?
Creo Elements/Direct Modeling 20.3.1.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Need to create chamfer in 2D editor.
4. What is the use case for your organization?
Saving design time.
5. What business value would your suggestion represent for your organization?
Will save (5) steps creating chamfer in 2D editor.
2 Comments
AR_2434111
2-Guest
To my best recall there was "create 2D chamfer" command much earlier versions, when  running by CoCreate, and I think that is Support/Development team overlook/mistake to take it out.
olivierlp
Community Manager
Thank you @AR_2434111 for your idea and welcome to the Community. Even though you provided the bare minimum information, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
I would strongly suggest that you elaborate on your initial idea to better make your case to the Product managers and other users. Here are some examples of well documented ideas.
Creo Parametric
Option to Import STEP file as Inseparable Assembly... - PTC Community
Make Shrinkwrap quality more scalable to data size... - PTC Community
Improve/fix the sheetmetal mirror feature - PTC Community
Element Direct
Add check for overlapping contours in „Unfold 2D“ ... - PTC Community
Creo View Illustrate Schematics
Creation of tangential dimensions following the ex... - PTC Community
