Hello Community,
As monitors get bigger and bigger for reasonable prices, more and more 40" displays can be found on a 4k resolution in the design departments. Running Creo Elements/Direct Modeling on such hardware is great, a lot of room for the designs. But the texts some how get unreadable and the only chance to change this, is on the operating system level to change the font size.
But this changes the entire UI. Would it not be a huge vale to have this independent e.g. the part browser with a kind of Zoom functionality, like in the view port with the mouse scroll wheel for the part browser, so that it becomes more interactive and the UI with an independent setting for the Icons and the Tooltips e.g.?
Or at least have more influence to set the font / font size for the UI, Tool tips and the part browser independent, some sort of the setting like in the Model Manager Preferences?
What's your opinion? Community, do you see a value?
Feedback is welcome!
Regards Thomas
