Modeling Dimensions With Advanced Design
- Ability to dimension between two point with the direction of the dimension adjusting with the two points as they move during a parametric update. Currently the direction of the dimension does not adjust with the two point causing an incorrect or at least an unexpected dimension value.
- Have a "parallel to" dimension so the dimension remains parallel to an edge, etc.
