I want the ability to distribute a "saved searchs" to other users.
There is thing called search conditions that everyone use.
There is no way to distribute now.
5 Comments
MaxR.Kublin
This Feature exists already.
Saved searches can be "local" (=user specific) or "global" (=available for all users).
MaxR.Kublin
Saved searches are stored as files in the Database.
With DB Server logging enabled, create a new saved search and watch/Monitor what is added to the Database.
Finding out how saved searches are implemented is for sure the faster way to get the functionality.
MaxR.Kublin
A saved search created by a user can be converted into a global search - however, not through the Model Manager U/I
I therefore regret a bit that I voted against this Idea.
In fact, implementing a global saved search is pretty straightforward.
MaxR.Kublin
Well, you can wait until you get a solution in the Standard product.
If you need the solution earlier, you can look for a consultant to implement it.
olivierlp
Community Manager
Status changed to: Archived
