I want to incline dimension lines other than parallel (Annotation Module)
0 Kudos
If the length of the extension line is the same, we want the horizontal dimension and the vertical dimension etc. to be able to tilt the dimension line.
In that case, there is no problem even if it is changed to parallel dimension.
