Direct Modeling/Annotation does not offer an option for adding an inspection rate including frame to the dimension.
We were able to use such a function with AutoCAD LT.
The workaround, adding a vertical line "|" and the rate in the Postfix might do the job, but the display is not according to standards.
This is dimensioning option which is used by many companies and really should be there.
