It is possible to customize the name of the Creo Elements/Direct Modeling icon by using the parameter title when starting the program:
SD.exe -e SDLANG=german SolidDesigner.exe -title "Modeling"
This is a very useful function as it is clear at a glance which of the icons in the start line is the icon for Modeling.
Unfortunately it is not possible to do the same for the icon for the ModelManager. It always reads "Creo Elements/Direct ModelManager", but as only the first few characters are displayed it is not possible to see the "ModelManager" part.
It should be made possible to customize the name of the ModelManager icon.
