ModelManager 20.2 upwards: Old Look and Feel
Until ModelManager 20.1 we had an option to switch to windows-like look and feel.
In run.bat:
set JVM_ARGS=%JVM_ARGS% -Dswing.defaultlaf=com.osm.ui.laf.ptc.PtcLaf
With 20.2 this switch no longer works.
Please modify Look and Feel like in previous versions.
1 Comment
thollerweger
7-Bedrock
Note: Java look and feel also causes changes in the behavior of operation.
For example:
When searching (Ctrl+F) in PTC LAF up to 20.1, I can enter the search term and then press Enter as many times as I want to jump to the next element. When the last element is reached, a message appears that no element was found. I can press Enter again to push this away and the search starts again at the first element.
With the Java LAF from 20.2 up, I have to press the space bar instead of the Enter key from the second element on. So I have to switch between keys, which is annoying and not known to many users.
