2D Jobs in Task Agent do not allow specification of the load rule (= Propagation Policy).
Solutions:
a) charging rule "as stored" as default - different load rule using XML on the server
b) load rule can specify when creating the job
c) charging rule can specify configuration job - like 3D jobs available
My favorite is the solution c) - that would be the most elegant and intuitive solution.
