Positioning with transform owner should should check for unreserved parts more intelligently
0 Kudos
Position 3D with Option "transform owner" doesn't work for (in MM) unreserved assemblies if you select in the viewport by selection frame. Then all selected  parts are excluded whose owners are unreserved in MM. Correct would be to first check which owners should actually be moved and only then check which parts are unreserved.
With the Modify 3D command  the same option works correctly. So the position command should be improved in the same way.
