The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Possibility of switching between content and copy/Advanced Assembly - relationship set
0 Kudos
Creo Elements Direct Modeling - Advanced Assemply/Parametrics
All Modeling Versions
If you have loaded multiple instances of an assembly with a relationship set in Modeling, the path in the relationships always refers to the originally created instance of the assembly or to the assembly loaded first.
This leads to problems if you want to edit the assemblies alternately. The path in the relationship set cannot be changed to the other instance, and thus numbering cannot be performed on it either.
It is not possible to change the relationship set afterwards, which would be very helpful
3 Comments
olivierlp
Community Manager
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (questions below). You gave some details but Product managers need context as well to document your idea. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
I invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
olivierlp
Community Manager
Status changed to: Clarification Needed
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
