Missing functionality in n WGM integration to CED Modeling: "Generate associated drawings on copy"
We are using large designs which are mostly customer specific. A new design is often based on a previous or standard base design, which is copied and changed where needed. In ModelManager the "Generate associated drawings on copy" functionality is used to automatically generate a copy of the original drawing and attach this copy to the new model. This saves th engineer a lot of time.
For now, migrating from ModelManager to Windchill causes a lot of resistance because the manual creation and storing of drawings from copied models is very time consuming. We need similar functionality in the WGM integration to CED Modeling.
