Could you add option to change position of the second units dimension ? From down of the dim text to right of the dim main value (Like Creo parametric drawing),refer to the picture A
The second units dimension just below display in Creo elements direct . it take up space in sheet when I have a lot of dimensions in the same side, refer to the picture B
