It should be possible to switch of warnings "Data will be loaded as a new drawing. Please confirm to continue" when load a drawing from Windchill Workgroup Manager to Creo Elements/Direct Modeling.
It is possible to switch of this warning with CED Model Manager using the command (setf modelmanager::*db-load-2d-enable-warning* :off).
At the moment it is not possible to have any automation with a drawing when a user have to agree this dialog manually.
