Security Alert Log4j Security Vulnerability. Click here to know more.
ability to change the background color of the viewport if an configuration is active
whenever you activate a configuration, you may want to have an other viewport color, so the user is warned about the fact that there is currently a configuration active. This will prevent him from doing design work, that is not adressed to the default position of the assembly.
this should not be dependant on a single selected configuration as the highlight feature, but whenever an configuration is activated, color should change.
1 Comment
mneumueller
Status changed to: Implementation In Progress
implementation is currently in progress for Modeling 20.5
