whenever you activate a configuration, you may want to have an other viewport color, so the user is warned about the fact that there is currently a configuration active. This will prevent him from doing design work, that is not adressed to the default position of the assembly.
this should not be dependant on a single selected configuration as the highlight feature, but whenever an configuration is activated, color should change.
