ability to change the background color of the viewport if an configuration is active
whenever you activate a configuration, you may want to have an other viewport color, so the user is warned about the fact that there is currently a configuration active. This will prevent him from doing design work, that is not adressed to the default position of the assembly.
this should not be dependant on a single selected configuration as the highlight feature, but whenever an configuration is activated, color should change.
2 Comments
mneumueller
Status changed to: Implementation In Progress
implementation is currently in progress for Modeling 20.5
mneumueller
Status changed to: Delivered
This has been implemented for Creo Elements/Direct Modeling 20.5.
See video  here: Graphical Activation Indication for Configurations
 and what's new pages here:  What's New in Creo Elements/Direct Modeling 20.5.0.0 (ptc.com)
