Changue 3D Annotation Orientation
Ed13
7-Bedrock
Hello every body,
When I create a 3D annotation in V.18 between two center holes, the new 3d annotation is perpendicular at  the base face of the holes (it is automatically). Can I changue this position and put parallel at the base face of the holes?
I try to do with orient 3D annotation command, but it is not possible.
Any solution?
Thanks in advance.
I think i understand the question. You want to pick user def. and use an edge, axis, or other geometry to define the direction.
Tom
Creo Element\Direct Modeling 20.6.0.0.0
Tom
Perfect Tom!!!
Thank you very much.
I have to activate first the 3D Documentation Module, here I find your answer (user def.pick).
Good support.
Best Regards.
