Creo Elements Direct Interoperability
jvadalia-2
11-Garnet
Hello Friends,
I have question about. How can i open CED 20.1 version files in CED 18.0 ?
Is there any option to do it. It is there the option of CGRI in Creo Parametric.
I have some files created in CED 20.1 version. Now the other subsidiary company wants to access those files but they are using CED 18.0.
Please help if some one have gone through such phase.
1 ACCEPTED SOLUTION
Look at this thread on the cocreate users group.  You will need to find the correct version name to make this work.
https://www.cocreateusers.org/forum/showthread.php?t=7478&highlight=bin-io-revision
Creo Element\Direct Modeling 20.6.0.0.0
3 REPLIES 3
PeterKehoe
(To:jvadalia-2)
Try this:
(frame2:bin-io-revision :MR-18-RELEASE)
That trick works as long as you only save your model to the disk.
Will not work if you are storing to Model Manager since the "save to Model Manager" code will
overwrite the setting each time.
