Creo elements dircet modeling 19.0 problem
bjyuen
7-Bedrock
At the beginning of useing Creo elements dircet modeling 19.0 was working well.
But after a period of use, the Select (F2) command and preselect command cannot work,  and the space function key is also disabled.
I don't know what the problem is.
bjyuen
7-Bedrock
(To:bjyuen)
It's solved.
Viewport setting-->Selection-->Preselection mode
bjyuen
7-Bedrock
(To:bjyuen)
It's solved.
