Creo elements will not start due to connection error and manual activation fails with a 404 not found error
Re: Creo elements will not start due to connection error and manual activation fails with a 404 not found error
Maby, my Creo doesn´t work too....
Hello FriedhelmK,
I followed your recommendations (date manually setup) but it does not work for me.
I hope the issue will be fixed by PTC soon.
Best regards
Good day all -
We are continuing to work the issue and I will supply updates as I have them.
Sorry for the delay and I appreciate the patience.
Best,
Toby
Good day,
Looks like this is fixed.
Please let me know if any issues remain.
Best,
Toby
Toby,
I can certainly get back onto the manual activation server. Thank you:)
However it is still not license checking automatically, is this still an issue?  Or is there a further step I need to take?
Niall
Hi Toby,
I just tried: I'm back in and everything seems to be going OK, Thanks a lot!!
Fred
Good day all,
I will provide updates here
Re: I get no license from ptc server and can't start ptc creo elements - is the ptc server down??
I will lock this discussion to stop duplicate conversations.
Best,
Toby
Sorry guys, this morning I've try to connect but have the same issue as last year, Is the server down again or it's just me?
Got the same problem since a few hours!
Hope it get fixed real quick, because i have a important project running. And just 2 weeks remaining for my degree dissertation in university.
Any tricks to start working again?
@Jaime_Lee
In the past, Toby has helped Creo Elements Direct users with a PTC license server issue.
See this discussion https://community.ptc.com/t5/Additional-Creo-Questions/I-get-no-license-from-ptc-server-and-can-t-st...
Seems like a problem on the PTC side has occured again.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
