Distinct in an OQL
Regular Member
Distinct in an OQL
All,
Does anyone know how to do a distinct in an OQL? I would like to get distinct
PI's in the following OQL.
//Create OQL object
pdm_error = PDMOQLCreate(&pdm_oql);
//Create OQLet search. PI
pdm_error = PDMOQLAddStringOQLet(pdm_oql, "PDMc_PI", ", "main_branch", ",
&pdm_oqlet);
//Create OQLet search. Branch
pdm_error = PDMOQLAddStringOQLet(pdm_oql, "PDMc_PIBranch", ", "elements",
", &pdm_oqlet);
//Create OQLet search. PIV
pdm_error = PDMOQLAddStringOQLet(pdm_oql, "PDMc_PIV", ", "release_level",
", &pdm_oqlet);
//Create OQLet search. Release Level
pdm_error = PDMOQLAddStringOQLet(pdm_oql, "PDMc_ReleaseLevel",
"((name='APPROVAL_PENDING') or (name='RELEASED') or (name='RELEASED_HISTORY')
or (name='RELEASED_NOT_MAINTAINED'))", ", ", &pdm_oqlet);
//Create OQL object
pdm_error = PDMOQLCreate(&pdm_oql2);
pdm_error = PDMOQLAddStringOQLet(pdm_oql2, "PDMc_PI", ", "folder", ",
&pdm_oqlet);
sprintf(szTemp, "name='%s", pdm_folderName);
//Create OQLet search. Folder
pdm_error = PDMOQLAddStringOQLet(pdm_oql2, "PDMc_Folder", szTemp, ", ",
&pdm_oqlet);
//Create OQL object
pdm_error = PDMOQLCreate(oql);
//Merge the OQL handles
pdm_error = PDMOQLMerge(pdm_oql, pdm_oql2, "AND", *oql);
Patrick Williams
Application Engineer
Steelcase, Inc.
RE: Distinct in an OQL
No,
What is happening is that I get back the PI several times because it has one
or more PIV's at any of those release levels. I want to get back distinct PI
names.
Patrick Williams
Steelcase, Inc.
Re: Distinct in an OQL
> From: -
> get distinct PI's in the following OQL.
> //Create OQL object
> "main_branch", ", &pdm_oqlet);
> ", "elements", ", &pdm_oqlet);
> "release_level", ", &pdm_oqlet);
> (name='RELEASED_HISTORY') or
> ", ", &pdm_oqlet);
> //Create OQL object
> "folder", ", &pdm_oqlet);
> szTemp, ", ", &pdm_oqlet);
> //Create OQL object
If all you want is a list of ProductItems, then why are you
adding branch, revision, version, and release level to the
query. Why not just do a "PDMc_PI" query?
With SQL, doing a query only on the PDM_PRODUCTITEM table is
guaranteed to give you distinct results. Once you join in
Revision and Version, you get multiple results for each
ProductItem.
For example 'select piname from pdm.PDM_PRODUCTITEM' will give
you the same results as 'select distinct piname from
pdm.PDM_PRODUCTITEM', except that use of 'distinct' will make
take longer, since oracle has to search for duplicates.
Marc
gib
