Good afternoon sirs
I would like to know if anyone is having the same problems that I am encountering.
I use Creo Elements / Direct 18.0 Copywriting, Creo Elements / Direct Modeling 18.0 with annotations, a few months ago, I replaced the hardware from an HP Z400 8GB of NVIDIA FRAME FX1800 8GB MS Windows XP 64-bit to A frame of 16GB RAM HP Z420 NVIDIA 2000 16GB MS Windows 7 64bit.
I found a significant loss of performance, especially in the 18.0 build. To make a trivial shift of a figure in raster mode, the figure flashes during the shift. The problem also occurs in other applications that I create, much less obvious, but they do exist.
Last remark, I noticed that the application is blocked by a much greater fraquenza than in the previous installation.
Does anyone have a solution to the problem?
I recommend you to install the version 18.10, which is a better version of the 18th release. No new licenses are required.
