How to Add Custom Frames in Drawing file?
SOLVED
Regular Member
Can anybody help me out for adding custom frames in CED Annotation file?
I tried the method suggested by PTC Tech Support but did not work in my case.
I tried below method of changing the am_customize file as below
;(docu-register-frame
;    :UI-name "Custom-A3"
;    :Wm-name ""
;    :file "C:\Custom_Frames\Custom_A3.mi"
;    :default :every time)     ;; T/NIL/:every time
But this did not work.
Still the same standard Letter sizes and A0.....A4 sizes are showing.
Please help....
Re: How to Add Custom Frames in Drawing file?
Wrong syntax i wrote.
; :Wm-name ""
Right syntax solved the issue aa below.
docu-register-frame
:Wm-name ""
:file "C:/Custom_Frames/Custom_A3.mi"
We have to copy the above syntax for all the frames to configure in am_customize file.
Did the frame show up in the drop down list when starting a new drawing?
When you said this did not work, what results did you get?
How did you create the frame?  Did you save it as a frame?
Issue is resolved.
Now its working.
Actually It was a syntax error in am_customize file.
Thanks All.
; :Wm-name ""
docu-register-frame
:Wm-name ""
Yes it is comments
Hi.
I do not know it well, but...
Is the character ' ; ' at the head of every sentence unnecessary?
It means comment.
Sorry, I noticed that this question was solved now.
