How to save shortcut and environment setting and import on another system
SOLVED
Participant
Hello Everyone,
I have defined some of shortcuts in Creo Direct, and would like to save all my customization applied to software and reuse on another system. How that can be?
Re: How to save shortcut and environment setting and import on another system
There is a user specified folder where all these setting will be saved.
At another system this directory will be created when you start the CAD at first time.
So you only have to copy and overwrite all these files, for example from USB-stick.
In CAD you can find this directory in "Options".
Unfortunately I have only the PE 3 in german version, but I did a picture in hope that is similar in V18 or V19.
Thanks Sir, I am truly greatful to you.
