Is there a way to connect part without viewset to drawing of part?
agracia
7-Bedrock
We have a couple of users here who somehow lose associativity between drawings in annotator and parts in modeling but the viewsets are still in the model so I can re-associate them.  But somehow the users are saving parts that a drawing was made from but the viewset is not available...any ideas if it is possible to re-associate a drawing to a part without a viewset?
Thanks!
1 ACCEPTED SOLUTION
I have had this issue before.  I actually duplicated the views in a new drawings, but did not save the new drawing.  This creates a new viewset identical to the one that was lost.  I then load the original drawing and attach the views to the new viewset.
Make sure that you are setup so that when a drawing is saved, it automatically saves the model.
I had this issue with one user on a regular basis.  I finally told him, that this is the last time I fix your drawing. If you lose your viewset again, you can just start the drawing over again.
He learned quickly to save everything.
Regards
Tom
Creo Element\Direct Modeling 20.6.0.0.0
5 REPLIES 5
Regards
Tom
Okay, so I made a dummy drawing in order to create the exact views in order to duplicate the viewsets from the original drawing.  I saved the model and opened it with the drawing I wanted to attach it to.  When I tried to attach the viewsets, I just kept getting a message that said "There are no viewsets found," but I can clearly see the viewsets I made attached to the model.
Is there a different way you are duplicating the viewsets?
Thanks!
I am assuming that you are attempting to attach the views via the migration tool.  I believe the issue is that it cannot find any available viewsets.  Try detaching the views first so that the viewset is then open and available to use.
It has been a long time since I had to fix a drawing like this. So I forgot that step.  My apologies.
Regards
Tom
I did not have to detach it. I tried it again and it worked! I think I was using the wrong Attach command (under Annotation instead of Migration).
Thanks for your help!
wdesmet
3-Visitor
(To:agracia)
you could use the migration tools to reconnect views.
load following line in your user input line
(docu-enable-migration-tools)
an additional tab will appear in Annotation.
regards
Ward
