Modeling direct 19 increse model quality
SOLVED
Highlighted
Participant
Hi, how can I improve the quality of models in modeling direct 19? where are the graphics settings of the application?
can I act directly on the Nvidia control panel?
what settings do your recommend?
Tags (1)
1 ACCEPTED SOLUTION
Re: Cut a long view in Annotation
I had written a manual for annotation several years ago.  I am attaching that manual.  This is for the full version of Creo Elements/Direct Modeling.  However, most of the information also applies to express.
I checked express and it does have the same function for cutaway views. See section 6.7 of the attached document.
4 REPLIES 4
Good Morning
Direct is not the same as Creo Elements Direct.  I suggest that you place your posts here to make them easy to find.
Are you referring to a broken view?
I really don't now how to call it, maybe broken view are the correct words (sorry, I'm Italian)
I mean something like in the attached draw.
In the meanwhile i found a solution by myself right clicking on the selected view and choosing broken view.
In italian is "Vista Interrotta"
Thank you so much
