Nvidia drivers setup for Creo Elements Modeling
Guest
Please can you help me about the correct Nvidia drivers setup for Creo Elements Modeling environment? If It's possible for Rel. 16 and Rel 20.2. In specific I need to know if the "OpenGl" mode is supported in Rel 16 and next in Rel 20.2. Thank You
3 REPLIES 3
Highlighted
Re: Nvidia drivers setup for Creo Elements Modeling
Hello ptc-93468.
As you may know, the CEDM 20.2 hardware support information is not yet available on http://support.ptc.com/partners/hardware/current/support.htm. CEDM 16 is so old that I don't think it's listed there.
Ok. Can you tell me this information about another version, before 20.2 for example.
Platform Support for CED 20.2 is available meanwhile:
https://www.ptc.com/en/support/refdoc/Creo_Elements_Direct_Modeling/20.2/Creo_ElementsDirect_Modelin...
However, the *real* Information Needs to be looked up by "Vendor", e.g. DELL, HP etc.
Check:
Hope this helps.
